Best TJ softtop?
Stuntman Autoworks
Instigator of things
Snow Camp NC 27349
I need a soft top for my TJ and I'm not having any luck finding a used one. Whats the best brand to get? Do they come with the rear frame part that holds it up?
I see there are also frameless options, are they any good?
Thanks for any help
Can't speak for the best....just can speak for what I have. The Pavement ends frameless I have has taken a SERIOUS beating and held up. It comes with a fold back feature too which is great for transition days
The zippers are YKK and are easy to deal with
I've been debating buying this top to replace my worn out Smittybilt top my DD TJ. How long have you had it? Are the back windows easy to get on and off?
Stuntman - What's your budget and intended use (dd or trail rig)?
6 years
Super simple
I assume it doesn't fold down and probably works best with a factory cage...?
Cyds cage...maybe not. My custom cage is slightly smaller than the factory+padding so fits fine. But does not fold down. Comes in pieces that can be separated and stuffed behind back seat though
Do you have a lot of those? No judgement...
$20 is $20
Not sure I follow. Your photos show a factory cage.
I was thinking about these the other day because I need another top and the framework on Cyd's is kinda fucked up. But looking at your pictures, it looks like it depends on the B/C spreader to hold up the side windows, and the C spreader would probably interfere with the back window. Trying to figure out if I misunderstand how they go together...
That was to show it whole, as well as what it looked like with no sides and back the way it came (with straps down to the top f the tub...I've since ditched the back and sides indefinitely and secured the very back a different way than it came.
Full top with new cage
How I roll now...same top..just no sides/back
This is the setup I'm running on my DD JK 2 Door, I have a buddy running the TJ equivalent setup;
The Windjammer is nice because it actually ties into the door surrounds unlike most that just wrap the b-pillar of the cage... Making it almost, but not quite, as closed as a regular soft top. There is an intentional gap at the top of the windjammer of a few inches to allow air flow even when everything is closed up tight. Air Conditioning and Heat have had no problems keeping up with it. I'd consider it a year round top as long as you get the MasterTwill, not the SailCloth. Biggest draw back for this setup is if you actually use the back seat, I tend to take mine out anyway...
And the setup is cheap to boot compared to a good quality twill soft top.
Cool, thanks. That helps a lot. It looks like the fit is a little dodgy if you don't have a factory cage.
I have installed numerous Bestop tops on customer rigs with no complaints as well as my own rides. Obviously I am partial to Bestop.
HOWEVER
I had a customer on a tight budget with multiple upgrades to her TJ so we went with the MasterTop full replacement top. Gotta say, If you didn't read the tag you'd think you were installing a Bestop. I was very impressed with the quality for the price.
I’ve sold and installed almost every version of every soft top. (Not to come across cocky; I say it like that because I’m sure there are some smaller companies that I’ve never used)
Bestop is by far the best CONSISTENT quality soft top available.
smittybilt, rampage, pavement ends(owned by bestop, to meet the needs/wants of the public for a less expensive top), rugged ridge, rough country, OffRoad Heros(not sure if they’re still in business or not), Quadratec, etc, all have their place and with good care will last you at least one season. The reason they are cheaper, is either they use a thinner vinyl for the windows, cheaper zippers, or less than stellar stitching which typically leads to ripped open holes and wet passengers. Or, a combination of the above.
For my personal jeeps, I’ve always used Bestop. For a quick flip Jeep, I tend to lean more towards pavement ends.
No matter what top you go with, make sure you take the time to let it sit out in direct sunlight to loosen up, before you try to put it on. After install, leave it buttoned up for a few days (I usually tell people a week to 10 days) to ensure that it’s stretches and contracts, and fits better for the long term.
Bestop sells replacement skins(no frame) and complete replacement tops(with frame). Most other companies provide the same, obviously at different price points.
Full, factory style tops are easier up and down, but typically take a little longer to put on at the beginning of the season. Frameless tops are easier to store, come with all new hardware, are pretty easy to put on, and give you a full length safari style bikini for the really nice, long ride days where you don’t want to be a lobster by the time you reach your destination.
windows in and out are the same essentially, either way you choose: plastic tabs, zippers and Velcro.
Sorry for the 3 post novel, just wanted to share.
I run the Mastertop setup year round and I like it. The new Gen 2 fits much better than my Gen 1 and at some point, I'll go ahead and upgrade.
So if you arent using the sides and back just sell me your setup and I'll give you my bikini top I have on my TJ now.
Thanks I don't see myself ever taking the whole top off for a ride, I hate sitting in the sun so just being able to take the doors, sides and back off is what I'm looking for. The flip back front section like @CasterTroy posted does seem cool for those nice days that are a little too cool for taking everything off. (kind of like opening a sun roof)
Dude I'd be all over that but I've cable tied the back corners and right behind the cab (made holes) and it would leak like hell from the roll bar back for you
