chuckkirch1969
New Member
- Aug 11, 2021
- Pattonsburg, Missouri
Update 08/14/21 fixed problem
2004 Jeep Wrangler X TJ 4.0 Manuel 5 speed
118,000 miles
Basically all stock no lift
Upgrades: Slip Yoke Eliminator-CV Driveshaft
I've got something going on with the engine there was no indication or warning it was sudden with no reason of cause I do not abuse my jeep it is my only transportation due to my hearing loss I can't seem to pin point exactly where it is coming from
My first guess was misfire due to bad coil pack so I replaced that was not the problem
Checked the plugs not the problem
Can't be flexplate broke or cracked it's a Manuel has flywheel but I checked it anyway not problem
So I take the valve cover off everything looks good nothing looses broken and oiled up good not the problem so I drain the oil for metal shavings or pieces not really enough to pin point a problem
So is it a broken piston?
From past experiences with internal failure breaking parts the knock doesn't go away it is continuous the faster you shut it off the less damage it will cause
Any opinion of what it is and how do you know?
Any input of what I should do next?
What is the cheapest easiest fastest best advice you can give me to get my jeep up and running asap
on a $500-$700 budget
what's my options
Im on work comp due to a preventable negligence causing me to fall 30' off a scaffold breaking my back, fracturing my left knee and tibial plateau doubtful I will be able to work again I didn't think it could get any worse that was wrong cause my jeep engine crapped out on me and things went from bad to worse I've got Dr appts physical therapy surgeries that the lawfirm I hired attorneys highly express I can't miss any or it will jeopardize what I'm sure you all already know money won't be an issue and I won't be in the jam I am now I just have to make it to the end
any help input opinion advice options is very appreciated and thank you in advance.. link to the videos hopefully they are able to help you help me
118,000 miles
what's my options
