Winch power cut off?
Jeffncs
Wake Forest
Thinking about installing a switch to cut power to my winch while I’m wandering around town….
This is one option I’m considering. Should I go a different direction?
Amazon product ASIN B00UPCG9ZS
Thanks for the advice!
all I know is I want to test lab one with 5,000 Amps like it claims
@braxton357 want to invest in a new youTube channel?
Get a Bluesea PN 9003e
Works great and the ratings are actually true. Takes 350amp continuous, 600amp during 5mn and 1200amp peak during 30sec.
I've been using it on a big winch with great success.
Amazon link :
Amazon product ASIN B002MJGSLW
Way cheaper here:
Amazon link :
Way cheaper here:
I've used a few of these. Never had a problem with one.
That's a good idea.
You can even make some cool stuff that plugs in the quick connects and use them for more than just the winch.
I have two 20' extensions for my Ready Welder. I can use the connection piece for a jumper. I have run into connectors that take the same size cables not fitting together because of a slight difference in the plugs, but, a little work with the dremel, and you are good to go.
I got the Mini's, so I can easily take the HF utility winch on & off, which raises & lowers my push blade.
I can also vouch for the Anderson Connectors being a great option. I use them in the industry but also have used them in the past on my XJs winch set up.
Send one to me and I can make your dreams come true. We have breaker testing equipment good for 60kA.
Will you film it? Do you have access to a slow motion camera?
