partiallycommittedracing
- Sep 8, 2005
- Huntersville, NC
Im trying to install my guages on my 22r.
The water temp guage needs to obviously be put somewhere where the water is. I have found some bungs on the top near the thermostat, but have a small problem...The guage has a screw in bung that is on the sender. It needs to be screwed into a larger bung in order to hold the sender in place (so it doesnt drop down or pull out of the hole in which it is placed. The only bung that i can find that will accept the bung thats on the line is too large to fit in any of the holes on the motor. Are there any other holes in which i can put them (larger ones?) Are there any bungs that go the opposite way? Larger at the top and smaller at the bottom?
Here are some pics:
This is the bung that is along the line (cannot remove):
This is showing how far it can go down the sending unit:
This is the large bung that accepts the line bung, but is too large to fit anywhere on the motor (and the smaller bung):
Screwed together:
This is showing the smaller bung and the line bung that will go in the motor, but will not seal up since the two cannot screw together (wont slide over the lip on the sending unit:
This is where I am trying to install it:
Does anyone have any other ideas? Anyone with experience doing stuff like this?
Here are some pics:
Screwed together:
