Detachable steering wheel
rokntoy
FUCKIN SLAYER!!!
Elkin, N.C.
Looking at putting a detachable steering wheel on my Toyota and was wondering if anyone has done this? What release did you use?
I used a nrg hub/wheel adapter and like it a ton. I have the hex weld on style on my tj and it has a lot more play in it vs. the nrg setup.
I've used the fine spline Quick Car and just welded it to the factory shaft on a couple TJ's. Can likely do the same on the Toyota.
This is the one I've used.
@Joe J. We used the Joe's racing version iirc.
Yep I got this one. Stays tight with zero play.
