5 Speed manual gearbox
Flint
New Member
Wellington
Hi, I'm wanting to put a ford 302 into my Toyota 1994 4x4 Landcruiser, any ideas on what 5 speed manual gearbox I can use with out to much hassle, look forward to anyones feedback. Regards
The 90s model trucks had a 5 speed option. Not sure what the name of the trans is though. It would be a factory bolt up as well as the transfer case. Not sure what kind of aftermarket support there would be for transfer cases for that but if all you want is factory bolt up, youre golden.
Ford used a ZF-5 and probably some Borg Warner transfer cased attached to it.
Awesome, thank you for the feed back Scottal.
I think the M5OD (Mazda 5 speed) was used in F150's with the 302. The F250/F350 variant would be the ZF S5-42.
Packaging wise, the M5OD will probably be easier.
