91samurai
- Apr 20, 2016
- Midland, Nc
If you keep the samurai rear you could shave the housing easily. both of mine I had the ring gear about an 1/8 from touching the bottom and It made a big difference.
Please don't ! You'll ruin the appeal of the lightweight / small / nimble samurai !
Just put the lockright and the 32s on the stock axle it'll be fine unless you drive like a retard.
@drkelly had 34" TSLs IIRC on his without troubles.
I would say different if you were racing.I doubt I'd gain a significant amount of weight from just the rear 60 series axle. I know the typical 8" toyota swap has very little weight penalty, but still, I get your sentiment: weight is weight. And driving like a retard is probably subjective. I do want to be able to lay on the throttle and not worry about stuff, but I'm not trying to shit-missile it off any sweet jumps or anything. I just want to avoid popping shafts and/or bending housings. Sounds like I'd be in pretty safe territory with 32s.
Your rig did great! It was a fun day and glad to see you making obstacles with it! All this rig needs is more seat time with you.Took this hog out to Kairos and ran creek bed trails for a whole day with some other CORE dudes. It was a diverse group of rigs which is always fun. It did pretty damn good. But being low and on little tires it was fairly exhausting picking lines and smacking corners and skids non stop. It did some stuff it probably had no business attempting, and the 2nd-3rd gear assaults definitely left their mark on the rock anchor rear spring hangers.
I still haven't installed the rear locker, so this was first time taking it out with the front locked and the electric power steering. The power steering was pretty great but there were a few times it didn't have enough guts to turn. Maybe I had some other interference between a spring clamp and the steering linkage, I dunno. I didn't want to break anything and utilize any spares.
Not too many cool pics as Kairos asks to keep the creek bed photos off the interwebs.
You can see from the below pic where it's parked back at the house that it's time to go ahead and finish up the rear bumper. I had to bend the poor mudflaps back down every time we stopped. Tailpipe also got a wee bit squished but not too bad.
I had a smart/stupid idea that instead of putting the lock right in the stock rear and still worry about popping a shaft, I could maybe run a 60 series cruiser rear axle so I could just not worry about it ever. They came with 3.73s and correct offset. I could run 5-to-6 lug adapters up front to correct for the lug pattern and get the width close. I would feel pretty comfortable running a 32 or so SxS stickies should I ever get the itch.
Anyway, it was fun as hell but I do think it could use a bit more clearance.
so far digging the build. I really want to find a cheap sami to get back out on the trail
The words "Cheap" and "samurai" are pretty much just antonyms these days.so far digging the build. I really want to find a cheap sami to get back out on the trail
And ditto this. Throw a sami front in it or yota axle swap it, and make memories.Thanks man, and I hear ya. The best part about them is everything is scaled down except the fun. I wouldn't turn my nose down at a tracker/sidekick either. More motor to start with and still compact.
IMHO, the canister is likely fawked from raw fuel... resulting from possible clogged vent OR being 35 years oldAnother fun drivability thing I've been dealing with, is anytime I fill it all the way up, it pulls fuel into the charcoal cannister which kills the vaccuum I guess and it sort of vapor locks itself. Anyone have any ideas?
IMHO, the canister is likely fawked from raw fuel... resulting from possible clogged vent OR being 35 years old![]()
You can buy a weld on steel pipe cap big enough to to go around the round part of the diff “cover” area and cut it in half for some easy diff armour. 1 cap is enough to do both axles since you cut it in half.
Yes, I stretched it about 1" front and rear. I ran the Kick/Track powersteering mounted with the Petroworks wedge bracket. It was spring under, and the steering linkage wouldn't allow more than about 1". In the back, my rear diff scraped/clearanced itself against the tank by denting it just slightly from the 1" stretch after I added that armor piece.@drkelly did you stretch your old samurai at all? Mine might be a smidge more than stock in the front based on how I did the RUF. I'm wondering how much I can do without steering and fuel tank interference. I know without moving the tank I'll be very limited, but like my wife probably says, even a few extra inches would be nice.
Thanks. Looks like I'll be in the same situation unless I goof around with another steering setup.Yes, I stretched it about 1" front and rear. I ran the Kick/Track powersteering mounted with the Petroworks wedge bracket. It was spring under, and the steering linkage wouldn't allow more than about 1". In the back, my rear diff scraped/clearanced itself against the tank by denting it just slightly from the 1" stretch after I added that armor piece.
