Anyone here do Dutch oven cooking?
We do a lot. Ribs, Mexican taco bake, various garlic and herb potatoes, Sausage based hash brown egg omelette, beans of sorts, cakes, cobblers, cornbread, muffins, biscuits, pizza and.........seared steaks, brats with peppers and onions.....and the list goes on.
Basiclly anything and everything. Even done bacon and eggs with pankakes on just the lid.
Best advice is a good lid lifter. I got a Camp Maid gadget I love. Making a oven tray table to cook off next. The Lodge brand is a flimsy piece of junk.
Definitely do the folded paper tucked in two spots under the lid for storage. Acts as a wick and let's it breath. Never pack it up warm it will condensate.
Buy a cheap pizza pan and you always have a surface to place it on. Also doubles as a firm spot for the feet in a canvas carry bag.
Charcoal starter. Count your charcoal. Become annal about it and adjust for wind, and outside temps. Be patient more heat can be added.....burnt is a no return.
Base for coals. Take size like a 12 inch drop 4 for the bottom=8. Now place Twice that number on top=24. That will net a slow 325 on temp. For well made ovens like Lodge it is consistent for all sizes. Weather and wind varies.
Items that scorch easy like cornbread parchment paper works wonders.....less clean up. Invest in a dedicated soft brush. If it's horrible let it just simmer or boil out......no damn detergent allowed.
If you cook spicy, or heavy on garlic for a meal....or onions. Double boil or hot hot water with minimum two rinses. Or else the blueberry muffins the next morning will have a twang.
Multiple entres run two or more. Save coals bank heat just stack em. What ever requires more heat or needs a longer cook goes on top. Heat rises.
Charcoal starter. No lighter fluid. Seeps into the iron even when burnt off. Them coal get chalky about 50 percent put em on. The preheat will do the cook time good. Place the coals with air space (don't pile) and keep the ash blown off. Kills the convection and insulates the wrong way.
Roll into it slow and have a beverage.
Ribs. I like St Louis cut. Get rid of membrane. Dry rub as you like. I prefer min 6 hour soak on them. Add a bit before cook as well. Place small raised grill as a trivit in oven. Cut one yellow pepper into slices. Do the same with a red and green. Pour one beer for yourself and another for the ribs.
Add beer to oven. Place ribs on trivit. Layer the peppers around ribs....I don't cover the meat.
Slow cook time varies, but add more beer if it gets dry. I've actually done some in 90 minutes that had good texture and not tough. I prefer to never boil then finish any ribs I do. I don't like them falling apart mushy.
These are best done as appetizers or a parring. You just can't fit a bunch in an oven. Stacking them doesn't let them breath and you might as well boil them.
Edit. As a note I don't do heavy sauces like bbq on anything I ever grill or cook....hence the rub. But plenty do ribs in a Dutch oven just like a slow cooker or crock pot, same slow heat just with coals.
Corn bread. Follow any generic cornbread recipe but try this......
Break the required in half and substitute yellow plain cake mix. It will be lighter, fluffy, and slightly sweet. Goes great with the seared sweet corn you finished in the other oven, lol!
Brown, hamburger. Add seasoning to taste for a taco flavor. Add some "jelopojoes" if you like a little kick.
For a cracker crust leave out parchment paper.
Layer flour tortillas shell on bottom. Add meat layer and smoother with favorite cheese. We like the blend cheese for Mexican dishes. Repeat tortillas and meat cheese combo till full or you run out.
Cook till nice and bubbly on top.
We prep this while the cornbread has already started. They finish about the same time.
Clean corn bread oven out.....parchment paper dump here.
Dump in a can of apple pie filling. Grab a box cake mix or canned biscuit for more of a cobbler. We like the cake mix. Add half a ginger ale. Dump copious amounts of brown sugar on top. Cook off while your stuffing the above down your pie hole.
Have the ice cream ready cause desert is next.
Looks like the 12" is the all around go to size. Is that what you guys are using?
I have a couple 12" and a couple 14". I like the shallow 12" and 14" lodge for making biscuits and other bread / cake items as it seems having the heat closer works better for me. I like 8" and 10" just as much. It all depends on what you want to cook, or if you are carrying it vs car camping.
Dutch ovens turned into a problem for me, like a lot of other things. I started with one and have maybe 15 now. I used to be able to buy a good camp oven at yard sales and the flea market for cheap, but like everything it seems they are higher than boat gas now.
I remember the first time I took my kids camping at the rental yurts at Natural Tunnel in Virginia. I told them I was going to make biscuits for breakfast and they all but called me a liar, until it was time to eat. Later that evening a young couple at the next spot over came over and introduced themselves as I putting together a dump cake like Warrior Welding mentioned above. They too had reservations about making a blueberry pie, until I set it out later in the evening.
I dutch ovened my wife the other night. She did not appreciate it.
Came here hoping someone would carry this torch....was not disappointed
We need to be friends, 😆.
You know that is something old, that isnt really an issue anymore. The lye in soap is what would take the seasoning out of the cast, but modern soaps do not contain lye. As long as you dont let it soak, washing cast iron with soap and water should not ruin the seasoning, if it is seasoned correctly.
I also recommend getting a chainmail scrubber for anything cast. It will really get those stuck on pieces off.
Just me and my wife.
I'd suggest a ten. And a Twelve. Some good stuff just don't fit in a ten. But a twelve deep will feed a plenty. I also lean toward the deep for all my ovens. Better heat distribution for me and always more room. I have cast skillets. grates, and flat pads for anything else...
If it was just one til your hooked get the 10.
Lodge has a free shipping coupon going on now if you spend 75$, but they do it just about all the time. You may find them cheaper locally too. Amazon has them too, but after getting some counterfeit air filters a few months ago I am done buying anything from them that I can get elsewhere.
If in the area of Sevierville, Pigeon Forge, South Pittsburg TN or Concord, NC, you can hit up the Lodge outlets. They usually have skillets and Dutch Ovens in the seconds area for pretty cheap money.
Going to revive this thread. Made an apple cobbler / dump cake in my 14 tonight while hanging out at Fall Creek Falls state park. I used a parchment liner, I think they work well when playing with sticky ingredients.
Spying I Hear You GIF by NOW WE'RE TALKING TV SERIES
^Me reading @WARRIORWELDING's post(s).... :laughing:
I've got a 12" Lodge that mostly sits in the cabinet. Damn, son. I gotta get that out and do some damn cookin.
