CLRracer
Mopar Nut
- Mar 20, 2005
- Archer Lodge
Well that's like stating the sky is blue or politicians suck. In other words, it's obvious. There will always be hold outs to any advancments.
Duane
Duane
My tundra hit 300k this week. It’s had take 5 oil changes or equivalent since 60k.You're not getting 10K+ mile oil change intervals with what the vehicle needs when that dealership maintenance program runs its course. Then its "Take 5s" and "Quick lubes" Cheapest goop you got $20.00 oil change.
Engine locks at 80K
Never had the coolant or brake fluid flushed (@RatLabGuy )
2015I'm not going down the one off vehicle example rabbit hole, but for curiosities sake, what year Tundra?
2015
Btw - for your one off.
My company fleet is at 159.
120 are 110k+ mikes.
This is in reference to the new vehicles with GDI engines dropping like flies, Toyota and Honda not included in the mfgs. in the original thread post.You're not getting 10K+ mile oil change intervals with what the vehicle needs when that dealership maintenance program runs its course. Then its "Take 5s" and "Quick lubes" Cheapest goop you got $20.00 oil change
Our fleet are equal parts ford and gm 2500/3500 has vehicles"It's a Toyota"
Plenty of our Hinos are still going strong 200K+ Emissions equipped with longer idle hours than drive hours.
What does equivalent equate too? If its not some teenager trying to work their way up from lube tech by doing the most and still screwing up I find that hard to compare to fleet maintence programs where techs are trying to do the least work possible and get the vehicle back on the road.
But this is getting off topic...
But I bet you've had to replace those rear discs and pads a lot though!My tundra hit 300k this week. It’s had take 5 oil changes or equivalent since 60k.
once.But I bet you've had to replace those rear discs and pads a lot though!
That's because they are not drums. I'm not sure if you've read much of the internet, but drums are the new hot shitonce.
Shockingly the rears wore out before the fronts.
once.
Yes, due to carbon buildup on the intake side because there's no fuel wash. This was a common problem on BMW diesels too, and the solution was methanol injectionAre GDI engines more prone to failure than conventional gas engines?
Maintanance starts to ramp up on most traditional ICE cars by 75k, 100k at most (by then you're at least into the 2nd set of brakes and a coolant flush).
Also I'm not willingly gonna give someone else that much potential control over my movements.I don't see my family becoming completely EV in my life. Odds are pretty good we will have at least one at some point, and for my wife it would make sense. But like you I haul too much too far to get rid of my truck on the current EV technology.
Duane
I'm curious what this is referring to? Not all EVs are all cloud-connected like Teslas. And you are currently limited by gas availability just like you would be electricity.Also I'm not willingly gonna give someone else that much potential control over my movements.
Do you have an example?Not all EVs are all cloud-connected like Teslas.
You dont think in a hard lock down situation that they wouldnt cut the power to keep you at home?? There's multiple places to get gas,only one place to get electricity.I'm curious what this is referring to? Not all EVs are all cloud-connected like Teslas. And you are currently limited by gas availability just like you would be electricity.
I can make electricity with gas.You dont think in a hard lock down situation that they wouldnt cut the power to keep you at home?? There's multiple places to get gas,only one place to get electricity.
Meh,perhaps.I'm just not wiliing to take the chance,I personally dont think in that situation they will care if you have power at home or not.Weren't they mad @ Tesla not long ago for not remotely shutting off the cars in Russia??I think your tin foil hat is showing.
But... he didn't..... so..... the system worked?Weren't they mad @ Tesla not long ago for not remotely shutting off the cars in Russia??
Oh contraire…You dont think in a hard lock down situation that they wouldnt cut the power to keep you at home?? There's multiple places to get gas,only one place to get electricity.
Oh contraire…
I can generate electricity anywhere with a solar panel, or a water turbine or a portable gen.
I can’t generate gasoline or diesel anywhere.
