Shreddinlettuce
- Nov 20, 2016
- Hickory
I see your fletcher and raise you west Asheville
It needed a wheel cylinder. I'll add it this reply a little bit later when I'm dropping a deuce and have more time. It was a pretty good story behind itNice ingenuity my man!!! Work smarter not harder.... now what does it need? Brakes and grease?
Needs more catalyst!
I like that the teeth imply that it will have some good bite. But in reality it will still just round off shoulders like normal
If you havenāt already, get a master cyl to go with, itās probably close behind, and with parts procurement the way itās been recently, youāll need the time to get it. One of the major after market parts suppliers was hacked so bad 2 weeks ago they JUST came back up yesterday and have to limit parts orders to catch up. Itās causing an issue for an already strained system (OEMs canāt keep up either)Have to take a break between doing brakes on each side. 800 mg Ibuprofen FTW!
Pedal has gotten kinda crappy for a few weeks. Took for-freaking-ever to get the correct wheel cylinders.
Anywho, seeing the condition of the old ones, along with them leaking, tells me the initial diagnosis was correct
View attachment 395153View attachment 395154View attachment 395155
Thanks man.If you havenāt already, get a master cyl to go with, itās probably close behind, and with parts procurement the way itās been recently, youāll need the time to get it. One of the major after market parts suppliers was hacked so bad 2 weeks ago they JUST came back up yesterday and have to limit parts orders to catch up. Itās causing an issue for an already strained system (OEMs canāt keep up either)
) and get it cleaned up and gone over before moving it into final position.Mr. Croc-head^^^
Is that Mr. Potato heads cousin?
Must have been a hell of a sight going down the road. A gladiator pulling a gto.Added to the family yesterday. She's old and can be grumpy when she's cold but who isn't??!?!?
1967 GTO - purchased from my father in law
View attachment 395212View attachment 395213View attachment 395214
