firetoy
- Apr 12, 2006
- lincolnton
these pictures are freakin badass... harlin is the sht:Rockon::Rockon:
FIRETOY... you got rid of the sbc, and put in a 4bt???
sure did
You left you my headlight, driveshaft, and RE joint.A list of carnage from our group
3 birfields(2 broke at the exact same time)
1 Aussie Locker
1 Lock-right
1 r+p
1 transmission or Clutch(not sure yet)
1 head gasket(still ran good all weekend though)
1 clutch master cyl
1 clutch slave cyl
2 headlights
1 voltage regulator
2 brake lines
1 power steering setup--on the way out on the last day driving normal!
1 broken bead...on an H1...hum, bought a set of tires and wheels already assembled and no pvc insert as advertised, someone is getting a phone call
1 CV
1 driveshaft
not to bad considering we were there for 4 days![]()
not a bad list...we had:
broken detriot (go figure) in a 60 front end
broken spider gears in a welded 60 front, shot the spider gears through the housing(yes the cast housing, not the cover)
inner/outter/joint on a 60 front alloy shafts
R&P in a yota
driveshaft issues in a yota buggy
alternator and battery
hub bolts in a yota
tranny in the FJ45
high steer bolts in 60
I got away with a pin hole in the radiator that water weld took care of.
I saw A LOT of stuff broken this weekend.
Is that the new one off the right side of 10?
R&P in a yota
hub bolts in a yota
tranny in the FJ45
I actually challenge them to a run, my rig against theres and they denied to race me.Ted should have come to Harlan for testing.
I think we could give him a run for his money on a short course
My detroit is broken too. I had to front dig many times just to be able to steer it.
edit: detroit is in pieces along with both lockouts. I guess they didnt like pinball very much.
You beat it pretty hard on the last part of mason jar as well, i kept waiting to see parts flying, that has to be the strongest 60 i have ever seen!!
