Tom@Hilltop_Machine
- Mar 31, 2005
- Rural Retreat, VA
We're planning to attend another Shadyside event. I'll touch base so we can meet up again.Man we were planning on going…then my son called and said let’s go fishin so I did.
If I’d have known I could pet the puppies I’d have been there
OER Racing Carburetor Kit 47mm Rod Type 40mm Venturi - Nissan L28 - RHDJapanI'm going out of my comfort zone and gonna try to make this run. The only thing that may indicate the last time it ran is the 14yo date code on the tires.
The tank will need to be dropped and cleaned judging by the smell when you take off the cap. Are you saying to ditch the fuel injection?OER Racing Carburetor Kit 47mm Rod Type 40mm Venturi - Nissan L28 - RHDJapan
Order one of these and get the tank cleaned out and she'll fire right up.
Halfway joking but totally serious. I would either do high comp big cam N/A on the L28 or SR20DET swap if it were my project. I had the tank restored on my 240sx earlier this year and learned a lot if you need any help.The tank will need to be dropped and cleaned judging by the smell when you take off the cap. Are you saying to ditch the fuel injection?
I've barely researched this revival, but for some reason I'm thinking this has an outside of the tank pump, but I could definitely be wrong. I do plan on cleaning the tank, new filters and pump. Hopefully that will give me an idea of why this rig was parked. Ignition and FI looks dead nuts simple. FWIW, this isn't my car. It's my daughter and son-in-law's project. I just need to make it run, drive and stop.View attachment 437316
Didn't take a picture of the hanger before but it looked just as bad as the pump.
Wait, so the squirrel caused the second blink, or the tech did?Had two power blips at work this morning. First one shut all three production facilities down. Got everything back going and BAM! Off and on again. After the second one I text the area supervisor to see what was up.
Tech did trying to knock the bbq'd squirrel down it sounds like.Wait, so the squirrel caused the second blink, or the tech did?![]()
Hopefully it was with insulated equipment and not an arm or leg!Tech did trying to knock the bbq'd squirrel down it sounds like.
Id bet he caught the jack with the hot stick and opened it.Hopefully it was with insulated equipment and not an arm or leg!
I don't know what that means, but you forgot to say "no homo"Id bet he caught the jack with the hot stick and opened it.
I doubt he would have sent me theHopefully it was with insulated equipment and not an arm or leg!
Your friends are less sick than mine...I doubt he would have sent me theif duder had blown his arm off
Guess you’ll be building that new barn, revamping the house and buying a beach house sooner than you thought. Congrats man. Happy for you!!Seems legit
And you picked them off shortly afterwards?i placed an 8' oak log in my pond for the turtles. They were on it within 20 minutes.
My thoughts as wellAnd you picked them off shortly afterwards?
Gosh man, you're so lucky. Between the Nigerian prince money, the peter pills, the hot local girls wanting to F now, and the rough cut untreated Coke 2x4 business, I don't see how you handle it all.Seems legit
