This is how you can reach me. | Old Jeep Carbs LLC
I am available from 0700-1900, Eastern Time, seven days a week, and will help you even on holidays. I may not be able to answer right away, but
He is active on a few of the old CJ forums all the time.Hope that guy is still in business! I'm headed to Asheboro!
Sal can help you out maybe, I thought the DJ was olderAdded a true 2" leaf pack to the front, from a 70-75 CJ5. It now sits level.
Also, I need to get the steering box rebuilt, any recommendations for that?
Thanks!
Sal can help you out maybe, I thought the DJ was older View attachment 444224
Replace the accerlator pump it is probably harden some and slow to push fuel till you get the pedal mashed down further and causing it to stumble before getting enough fuel to match the air interduce to the motor .Oh, and 'nutterd' it and it runs much better.
still wants to stumble and occasionaly die at light throttle, like when backing out of the driveway, but at this point I'll try and tackle that this winter.....along with trying to upgrade the brakes,
Pretty sure a steering box from an H1 would weigh more than the entire jeep.
I used to be real good on carbs 30 years ago but since fuel injection i haven't touch one in several years. I have forgotten more than i can remember now on carbs.I'll investigate....i sent the carb off for a professional rebuild in June.
However the accelerator pump not functioning properly does seem like the culprit.
You're missing the point of this hobby.I'd love to add a basic AFI kit on it, but I'm trying to keep this thing cheap and simple.
I don't need a $10k DJ that is worth $5k.
cries in poor......
HA!You're missing the point of this hobby.
But then again you don't have a spare tire so I guess you are too poor/cheap to do it the right way.![]()
