RatLabGuy
- May 18, 2005
- Churchville, MD
I posted about this in the random pic thread at a while ago, but figured it was about time I actually did something about it.
My 93 Toyota pickup has some serious rust. Well duh, it's a standard factory feature.
A couple months ago the back end got randomly really bouncy. I went to look under it to discover that both of the rear shocks have broken off at the mount... From rust. In the process of replacing them I discovered that there was just a, um, wee bit of rust deterioration at the crossbar the 2nd mid frame crossbar where it attaches to the frame.
It wasn't even connected on the passenger side. Driver side is only marginally better.
So I of course fixed it properly...
Decided it was about time to fix it properly, so I pulled the bed off to get a better inspection.
The driver side is connected, but only holding on by hopes and dreams reminiscent of a Democrat's economic plan
Passenger side is just gone
Currently have it held up with a jack stand under the gas tank.
Luckily the only thing this bar seems to do is to hold up the back end of the gas tank, but I find it a small miracle it didn't fall completely. I find myself extremely thankful that the shocks broke!
My plan is to go ahead and cut this sucker off and clean up the frame inside of it as much as possible. Only time will tell how much there will be left to weld to. I assume I will need to weld in some fish plates for a new crossbar to attach to. Luckily I have a good friend who is a TIG master that's offered to do it... With the entertaining part being that I'm going to have to get it to his garage.
Right off the only immediate question I have is how to handle the gas tank bracket. It appears to be welded onto the crossbar, which obviously will all just go away. So I'm not real sure if there is an ideal way to cut it so that any part can still be reused, or how I will reattach when the time comes. At the moment I'm thinking I will probably leave part of the original bracket on the tank, drill some holes, and fabricate a bracket for the new crossbar that it can bolt to.
