mbalbritton
- Mar 22, 2005
- Greensboro, NC
So, I’m sure I’ll have lots of questions, so I thought I’d start a thread. I’ve been into engine and stripped them before, but never “built” one. I use built lightly. This will either turn into a 4.0 refresh or a 4.6 stroker. Or maybe just refresh and then stroke it down the road. We’ll see as we get into it.
What I’ve got: ‘87 YJ 4.2 with an Mc2100 backed by an A999/207 combo. This 258 has been fairly typical. It runs and won’t die. #5 piston slaps like great Friday night! Or whatever night nookie nights for you.
I picked up a ‘94 4.0 from @spraypaintman of unknown quantity to both of us. But all signs we could check looked good. I’m guessing that it came out of an XJ, but don’t really know as it wasn’t original to the YJ we pulled it from. If anyone has any tell tale info about Configuration or marking or something, let me know. @Blaze who posted the 4.0 thread and seems familiar with these.
I picked up all unmolested wiring and all accessories that were attached. I’d say I’m 95% complete with parts. I’m sure that will drop as I go along and realize I need something else. So far, a cooling fan and power steering lines.
Here’s the fun stuff, first PICTs:
And tear down:
First problem:
So… what I know so far about this engine from tear down.
- valve cover gasket Was coated with blue RTV
- head is cleaner than the block
- dropped a borescope down all spark plug holes and everything looks good, even has nice crosshatching on walls. I’ll see if I can pull some PICTs.
- intake was misaligned on last install and there was clearly a leak and a broken alignment tab.
- all pushrods feel true and under proper tension.
- all valve train moves freely and properly when spin by hand.
- there was no bell housing or starter so I have not heard it fire, turn over, checked compression…
- ALL intake and manifold bolts were able to be loosened with about 5lbs or pressure.
- no accessories seemed to have been recently removed.
- all spark plugs were consistent with a very light coat of black.
-No real apparent Oil leaking. Might could use a new front and rear main seal…just because it’ll be easier now.
Soooooo. That’s where we’re at and here’s what I’m debating.
Clearly someone has been into the valve train. There’s good signs the head has been off, maybe even replaced. I found an 0630 casting on the head, which I understand to be ‘96 and newer. I’m not seeing any cracks from the topside on visual inspection.
I’m thinking I’m going to pull the head and inspect for signs of over heating. Note that I did find that apparently some squirrels stole the Thermostat and replaced it with acorns.
I’m also tempted to drop the pistons and check them for crack. Might as well at that point I figure.
Thoughts going forward at this point:
- keep it EMP proof and put the carb and intake from the 4.2 on it
- leave it as is and figure out the wiring
- stroke and carb it.
- stroke and inject it.
Oh, and I’ve stated it many times before. I freaking hate wiring and electrical. For some damn reason, I just can’t wrap my head around it. For that reason alone, I’m tempted to go carb and keep it simple.
So, until next weekend, that’s the start.
Anyone around Greensboro/HP have a tig welder that could help me with my intake?
And tear down:
First problem:
