orange150
- Mar 20, 2005
- Fairfax City, VA
May as well stroke it
Buddy, I've been into more 4.0 and 258 than most so take the following advice.SON OF A…MUTHA FLETCHER…
So last night I pulled out each lifter, one at a time to inspect the bottom face and put them back. One at a time as to have no chance of mixing them up.
Then tonight I wanted to measure the rod journals to see if they were standard or undersized. Not even thinking about it, I spun the block over and hear 9 of the lifters fall out and scatter across the floor or fall into the oil drip pan under the engine stand.
FAAAAAAAWK!!!!
It’s one of those things you constantly hear. Don’t mix them! I know you can’t always see issues or differences, but looking at them… they “look” and feel the same. I was halfway inclined to say fuck it and not even talk about it.Buddy, I've been into more 4.0 and 258 than most so take the following advice.
Don't lose a moments sleep about it.
Ideally, they're all go back in the hole they came out of. But you ain't gonna hurt a thing if you don't.
Over my 25 years of wrenching and building 4 liters, you know how many times I used a valvetrain organizer? Zilch.
Rockers go back where they fit, as do pushrods.
As long as one particular line isn't chewed up (where it would be obvious) put em back where you wish. If you feel the absolute need, replace the lifters with some parts store replacements and rock on.
You'll be just fine man.
Especially when I have a stroker crank and rods for saleLook here, this isn't the kind of advice he needs to be hearing. It's not very conducive to making it into a stroker.
Duane
Digital calipers. Psh.Forgot to mention the real kick in the nuts.
After gathering up all the fallen lifters and setting them in the work bench, I grabbed my calipers to measure the journal and the battery was dead in my calipers…as well as the spare battery. FFS…
Like this engine, run what you brung.Digital calipers. Psh.
Might as well, for ease of mind.Spend the $5 on plastigage already
FAAAAAAAWK!!!!
Mic’d the rod journal out at 2.095 looking like this crank hasn’t ever been undersized.
So, in my curiosity and desire to understand how shit works, I was looking at some of the lifters that are randomly organized on my bench. I grabbed a pushrod and pushed down on the lifter plungers. Some moved some didn’t. Figured since they’re mixed, why not screw with everything a little more and open one up. So I grabbed one that wasn’t moving, pulled it apart, sprayed and cleaned everything out, lubed and reassembled. Now it moves and is springy. Cool. I don’t know if this was right or wrong of me, but I figured I had nothing to loose and everything to gain (knowledge, either immediate or latent).
So I started going through all of them with similar results.
I’ve seen two different approaches online for reinstalling. One said submerge the lifters in oil and let them sit. I’m Assuming this is to fill
With oil. The other said, for used lifters, to compress them and bleed them. That you didn’t want to crank it charged with oil. That you could bend pushrods. That sounded ridiculous to me, because they would fill with oil after running.
Soak em for an hour or so in motor oil. Install head and gasket, torque head bolts to spec, with a healthy application of pipe dope to driver front head bolt, torque rocker to 24 ft/lb.Mic’d the rod journal out at 2.095 looking like this crank hasn’t ever been undersized.
It’s a signMay as well stroke it
Stroke is too short.Pulled the main caps and rod bearings. All rod side bearings were worn through to the copper. Is this normal or a sign of something?
View attachment 447313View attachment 447314
That’s what his mom said too!Stroke is too short.
The 94 doesn't have TBI injection, it has multi port fuel injection and yes it has a CPS.I didn’t look, and the transmission was already gone on the donor, but would this ‘94 4.0 with a distributor and TBI have a CPS?
If so, what do I need to be planning if I stay with the a999 for the time being?
Also, is there a way to bypass or work around the O2 sensors, or be a good boy and put a Cat and O2 sensors on the YJ?
Any other things like this I need to factor, in order to adapt this ‘94 4.0 to my ‘87 YJ?
