- Mar 20, 2005
- Hendersonville, NC
Those losers sound like they have crappy rigsDream come true. Took me places other cool kids couldn’t go..
or too much air pressure in their tires…Those losers sound like they have crappy rigs
RadDream come true. Took me places other cool kids couldn’t go..
You’d go through more than $100 worth of drill bits getting those out, that’s a good plan.And here’s what I found. All 6 allen head fasteners that mount the adapter to the Atlas sheared off clean. I believe I’m gonna follow @Bebop suggestion and just order this piece from Advance Adapters and have brand new threads without fussing with extracting these. Probably do a little research on getting some stronger bolts to put back in.
pitstopusa.com
All my studs are in great shape, but I’ll definitely look into the ARP variety. 4 are 50mm and 2 are 40mm. What I need are the 6 allen head bolts stronger. Everything is 10x1.50 threads.You’d go through more than $100 worth of drill bits getting those out, that’s a good plan.
looked up the specs for those studs, can’t find length on the website, but arp makes a header stud in 18ksi that has the same thread combo and 2” long
ARP AJ2.000-5G Header Stud
Pit Stop USA has Exhaust Manifold/Header Fastener Kits like ARP Header Stud 3/8" Diameter 2.000" Long Chromoly - Black Oxide at low everyday prices. Be sure to check out our Engine Fastener Kits.pitstopusa.com
Left is stock atlas right is generic header stud, the atlas one has a 1/8 stick out past threads that would help in alignment, but the arp would work just fine (images from pirate 4x4 atlas thread)
Oh, I thought the studs sheared offAll my studs are in great shape, but I’ll definitely look into the ARP variety. 4 are 50mm and 2 are 40mm. What I need are the 6 allen head bolts stronger. Everything is 10x1.50 threads.
Got some 12.9’s in a cart right now. Just gotta get some measurements and then start throwing my purse at it.It seems like most of the fasteners AA use are just grade 5 or metric equivalent stainless. You should be able to easily find some 12.9 metric bolts. I’d bet they sheared because they had worked loose and the rotational force took them out though.
Fairly common sadly.It seems like most of the fasteners AA use are just grade 5 or metric equivalent stainless. You should be able to easily find some 12.9 metric bolts. I’d bet they sheared because they had worked loose and the rotational force took them out though.
I have a couple of buddies who cannot keep their atlas tight to the transmission and they somehow always work themseves loose.
@BigSouth I'd make sure to use red locktite and the proper torque recommended from AA.
Add another one here. Part of my bolt check before every ride is the bolts between the atlas and AX15. 2-3x a year I find at least one or more loose despite blue loctite. Red is next.
Yea the case would definitely bust before those bolts come looseBolts never back out on my Dana 300! Yes! Finally some way that a D300 is better than an Atlas!![]()
Where were you 2 weekends ago?Gotta wheel it for the bolts to have a chance to back out![]()
Where were you 2 weekends ago?![]()
Ok trying to learn and understand what is going on here and what happened. Does the atlas have an adapter that bolts to it and the studs go in it? I would have thought the studs go straight in those drilled and tapped holes.And here’s what I found. All 6 allen head fasteners that mount the adapter to the Atlas sheared off clean. I believe I’m gonna follow @Bebop suggestion and just order this piece from Advance Adapters and have brand new threads without fussing with extracting these. Probably do a little research on getting some stronger bolts to put back in.
The Atlas has a clocking ring bolted to the front of the case. The studs thread into that and then those bolt to the adapter on the trans. The way I understood it the socket head bolts holding the cocking ring to the case are backing out causing the issue.Ok trying to learn and understand what is going on here and what happened. Does the atlas have an adapter that bolts to it and the studs go in it? I would have thought the studs go straight in those drilled and tapped holes.
Yea I don't think I have ever seen one other then installed from underneath. So I went and looked on their site. Seems like a bad idea to me....but what do I know. Also see hindsight...The Atlas has a clocking ring bolted to the front of the case. The studs thread into that and then those bolt to the adapter on the trans. The way I understood it the socket head bolts holding the cocking ring to the case are backing out causing the issue.
So here’s all the pieces to the puzzle. Here is the input of the Atlas the way it comes from them. It has multiple threaded holes to allow clocking the case.Ok trying to learn and understand what is going on here and what happened. Does the atlas have an adapter that bolts to it and the studs go in it? I would have thought the studs go straight in those drilled and tapped holes.
Not really any different from OG clocking rings we all used putting 300s into later model Jeeps back in the day.Thanks. I see now.
