@Jody Treadway @KrawlerTJ @Curtis_H was a good weekend even if cold and broke lol
guess me and curt get to load up in the cold in the morning
Look at that wire fencing in pic 2. I'd build a fence just to have a reason to use it! Moto-graders are cool too, but I just love some antique fence wire lol
Sharkbite over cpvc, if so thereās a $10 tool that will loose the sharkbite and you can replace the valve easyAnyone seen or dealt with a toilet supply line valve like this?
Iāve never seen one, but it seems to automagically and seemingly randomly shut off.
That round knob looking real is a pop in/pop out type valve. Three times now Iāve gone in and thereās no water in the tank and that thing is pushed out. If you push it back in, it opens the valve and starts running water again.
Iāve never seen anything like this and donāt know why it keeps shutting off.
How old though? It seems the zincs would keep that from happening at that low of hours.Has about 360 hours on it. Sad really. The port motor is still running, but I suspect it's insides look just like this. It was missing pretty bad so I fed her the onions to "blow it out". Got up to 3800 rpm a couple times before the diagnosis began. Thought maybe plugs but found the milk pretty quick and went back to the dock...
My cousin's house is plumbed with these. Hers under the sink started popping off and she had them replaced with standard quarter turn cutoff valves.Anyone seen or dealt with a toilet supply line valve like this?
These are 2005 engines, so there's some age. Dad would fresh water flush these things to a fault though after every use. Which obviously wasn't much based on the hours...How old though? It seems the zincs would keep that from happening at that low of hours.
That's how they fail when wore out.Anyone seen or dealt with a toilet supply line valve like this?
Seems like a pretty dumb/cheap part.That's how they fail when wore out.
Itll be a continual problem until you replace.
if you google accor flow tite you will find more info than you cared toSeems like a pretty dumb/cheap part.
Damn, way back in the sixties people were already tilting cameras to exaggerate grades!
He stole the wing off a super bird!Damn, way back in the sixties people were already tilting cameras to exaggerate grades!
