4 door Tacoma family wheeler
So there’s no updates I’ll dust off my chassis and drop it off…
Speaking of…what’s the updates on this thing??
Update: I standardized my sterling and got it back together.
But also.. bring it on.
Does anyone have recommendations for a transmission shop around Greensboro or asheboro?
I have a 2wd a340e right now and bought a cheap a340f 4wd trans.
Right now my options to convert to 4wd are;
Swap the output shaft from the a340f to my current trans, or swap my current valve body and torque converter to the older a340f 4wd trans.
I could probably do either one here, but not super confident about diving into an auto transmission. I’d like to at least try to get an estimate on a rebuild and swapping the output shaft.
Had a little bit of time to work this weekend. Made a decent pile of parts.
Moved the axle under the truck to get an idea on what needs to be moved and how much. This diff/truss is huge and takes up a ton of space. Waiting on rear sump oil pan to get a better idea of where things will sit.
Got a rear sump pan put on. The axle truss and oil pan where never going to be friends, so the truss got a little modification. I drew up a new front frame section, and now waiting on that to get lazer cut.
In the meantime I built some new jackstands to raise the truck up more and get the frame leveled out.
The last pic will hopefully be about an inch or two higher than actual ride height. Im shooting for 5” up travel, and trying my best to keep it low. Already planning to raise the motor a touch when the frame is redone. The motor mount and upper link mount look like they will be close so I’ll probably need to change those up a bit too.
Had some time to make my Toyota/poly motor mounts. I got the frame rails tacked on last week and spent some time today making sure everything was square and level before burning them in.
Motor mounts tacked in place.
I guess next big step will be figuring out the trans. Then I can mount the tcase and work on a cross member.
Dove into the transmissions today. Decided I should throw a sonnex zip kit in the valve body while I had it out.
Changing the valve bodies was pretty straightforward. Instructions were clear on the zip kit. Everything went pretty well I think, until I had to dress my transmission up like a kill room… went to Install the valve body and something didn’t feel right. The newer housings are milled to clear the shift solenoid, that was new information to me. Que the plastic and burr bit. It’s all in there now. Hopefully everything works.
