kaiser715
Doing hard time
- Jun 1, 2006
- 7, Pocket, NC
Never thought cellular could be this fast.
Hit this on Verizon the other day. Simply amazing.
That’s faster than the dang wired connection!!!
That was at a stop light in Ballantyne when I upgraded to 5GUW. They had just installed the 5G (towers) lamp posts.That’s faster than the dang wired connection!!!
You out here getting data the same way the government does haha!That was at a stop light in Ballantyne when I upgraded to 5GUW. They had just installed the 5G (towers) lamp posts.
Did you set it up on your home mesh network? On my Verizon router I used IP pass through mode to setup my mesh network. Looks like Starlink calls it bypass mode. StarlinkThread update.
I hopped on the starlink rental deal, $39/mo for 6 mos then $50/mo after that for 100mb service. Figured why not. Got it all hooked up this afternoon. Seems like a super solid upgrade so far. First Pic is from my current brightspeed network. Second is from the starlink.
Yes. I just plugged it in the back like the tech Neanderthal I am. Im sitting under my barn shelter right now and am hooked up to an eero at half strength, my kids are in the barn streaming something on TV and it just pulled 40mnps.Did you set it up on your home mesh network? On my Verizon router I used IP pass through mode to setup my mesh network. Looks like Starlink calls it bypass mode. Starlink
It may not give you trouble like you have it setup but if you start having network issues I would setup pass through and not use the wifi from the starlink. If the Starlink and your current network router are using the same IP scheme you will run into routing issues. For example if both routers are using 192.168.1.1-254.Yes. I just plugged it in the back like the tech Neanderthal I am. Im sitting under my barn shelter right now and am hooked up to an eero at half strength, my kids are in the barn streaming something on TV and it just pulled 40mnps.
I read about the pass through mode but haven't dug in to figure it out yet.
I bypassed it this afternoon. I was looking in the wrong settings menu yesterday.It may not give you trouble like you have it setup but if you start having network issues I would setup pass through and not use the wifi from the starlink. If the Starlink and your current network router are using the same IP scheme you will run into routing issues. For example if both routers are using 192.168.1.1-254.
That speed is almost definitely just a reflection of your internal network speed, not the potential speed of the dish.This thread had me curious.
This is Starlink through a network of extenders around the property. My home office is in our detached garage about 40 yds from the actual router. Work well enough for wifi calling as well.
Yes. Its a rental. I placed my order on the starlink website and I think it was like $20 or something nominal when the order was placed. Then a $39 charge for the first month after I activated the equipment. Cancel the service and mail it all back.Does this 39/50 per month starlink deal include the receiver and such or is that a separate purchase??
