Cage gussets Q
Jeffncs
Wake Forest
Installing cage into my early bronco. It’ll see trails and street. Clean but not restored…. anyway…
Cage has 3 hoops at A,B and C positions. Spreader bars connecting each.
Should I gusset inside and outside of the outermost spreader bars or is the inside good enough?
Installing rear spreaders this weekend and want to button it up completely if I can.
Both sides is certainly better, but one side is tremendously better than none.
You talkin taco gussets or grab handle style?
I made a tool for making taco gussets in my press brake. Always thought that was a good way to gusset because it’s low profile and strengthens the weld and adds a lot of strength due to multiple planes now being in play.
Thats what I was going to suggest. I did some like that for a cage I built, AKA taco gussets.
I like the look of both the tube gussets and the tacos (mmmmm, tacos!)
I have some drops around that would work for tube gussets…. I don’t have an easy way to make the tacos so may test fit a tube gusset. If it fits well, I’ll likely go that way and remove the 4 triangles I installed. (My welder started acting funky on on #3 and 4 so had to grind on them anyway.)
Thanks guys!
Thanks guys!
Barnes has em for tree fiddy
