Custom PTFE Hose in Charlotte Area
holdmypocket
Member
Charlotte
Anyone in the Charlotte area able to make a custom high-pressure power steering hose using PTFE-lined hose and crimped fittings? Or know of any place that will?
I can bring in my existing hose to have it duplicated with the correct fittings and length.
The one I made out of stainless braided and reusable AN fittings with the Koul tool blew steering my 40's on dry pavement and I just want the insurance of a permanent crimped fitting made by someone who knows what they're doing.
This is who we use locally to build hoses for some our lubricating systems at the plant I work at. We may use them for hydraulic systems too, not sure though. They are in Charlotte.
Ive used Livingston Hose off Westinghouse a few times. Really good guys.
A buddy recommended carolina hose up in the university area but I was on the southside of town so Livingston was closer.
I've never personally got teflon lined stainless from either of the above, but both can do it.
My go to was actually in Rock Hill Cardinal Rubber....they can make any hose, will dot seal brake lines and even have a cnc tube bender...I've handbuilt hardline templates from hanger wire and they produced em while I waited. Including combo hoses.
Get some cheap clear plastic hose and some push to connect fittings off of amazon and mock up your lines making sure to put sharpie lines to show orientation in case something shifts, that way they you’re sure they are made right the first time if you don’t have one to copy
I will second Livingston. again not sure what they carry.
