Making custom driveshafts
Joe_U4
Raleigh
After twisting the carrier shaft back in July I started thinking about making new driveshafts. I have spare front and rear shafts made by Tom Woods. Over the years I've beat the snot out of them and they have held up well. However, the coating has worn off the splines and I twisted the splines on one. The buggy is never going to see street use so perfect balance is not that important. Not to mention after the first rock trail and the abuse they take they no longer would be balanced.
So, after watching a few YouTube videos I quickly became an expert on driveshaft building :D To simplify things, I researched driveshaft kits from a few suppliers and found exactly what I wanted. DIY 1350 2.5" tube kit with all Spicer components. I ordered two 1350 driveshaft kits and a carrier bearing kit from a reputable company (will remain unnamed). Upon unboxing the components, I thought the 1350 yokes looked a bit small but didn't pay it much mind. Fast forward a couple of weeks and I get ready to start building the shafts. First thing I notice is the 1350 yokes have a weld flange OD of 1.77". The tube is 2.5" OD .250 wall with inside of one side turned down to 2.030". I can math and yoke with a 1.77" OD does not fit inside a tube with a ID of 2.030" 🤷‍♂️ I figured someone picked the wrong yoke with boxing the stuff up. I called and explained that I think I was sent the wrong yoke. They asked me to text them pictures of the yoke.
The response "Hi Joe, I pulled one of the Spicer yokes 3-28-777 off of the shelf to verify the casting number on the yoke. The casting number is the same as yours, 3-28-239. I measured the shoulder (were the tube sits) and it measures 2.030" and the butt measures 1.77". The yoke you received is the correct yoke for the 2.0" x .250 wall tubing. The yoke will sit all of the way down into the tube for welding - picture below. "
WTF That's not where the yoke is designed to be welded :confused: I looked up the Spicer part# for that yoke and it's made for a 2" .120 wall tube (doh). So I politely questioned the welding position and noted that yoke is for a 2".120 tube. I was a bit shocked at the next response: "The yoke should slide all of the way into the tube until it stops against the ears. This is the proper weld location. The 2.5" outside diameter tubing with a .250" wall thickness has the same 2" inside diameter as 2.0"x.120" wall thickness tubing. We run thicker wall tubing to provide additional strength in the driveline. The yoke that you have is the correct yoke for the 1350 DIY driveshaft kit. Thanks, ****" My response was simple "No problem, I'll throw these in the trash and order the correct yoke elsewhere".
I have never seen a yoke welded in that location and I'm fairly certain Spicer made the weld flange for a reason. I am not comfortable welding that yoke at that location and putting excessive heat into the u-joint ears. Engineers design parts a certain way for a reason. It might be fine and it might not be, but I'm not doing it!
Thoughts? Would you weld that up and trust it?
Turns out Spicer does not make a yoke for 2.5" .250" wall tubing. However, Northern Drivetrain does part# NDT-00164 but it's on national backorder and has been for some still. Work around: use a Spicer SPI-3-28-427 (3.5" .083W yoke) and a NDT-00141 (Tube yoke adapter 3.5x.083 to 2.5 ID). Ordered two of each.
Alternate yoke: Spicer 3-28-47 (2.5" .083W yoke). It has a flange of 2.345 which will require it to be turned down a bit and the tube to be opened some. Maching both the yoke and the tube should keep the thickness of both to an acceptable tolerance. Ordered and waiting on it to arrive today.
The plan it to make one of each type and determine the best solution. Last night I started making the front DS with the NDT adapter and larger #427 Spicer yoke.
Tube cleaned up:
Ready to cut:
Yoke and adapter
Got the tube cut to length last night and will try to get it assembled this afternoon.
Last week I spent some time making an arbor with a live center to fit a yoke so I can try to align the DS in the lathe. We'll see how that goes 🤔
Arbor before making the live center
TBC...
That may be how "they" do it, but that's not right. There is a longer turned diameter on the flange with an OD that should match the ID of the tube (or even have a light press fit), and the tube should press until it stops against a shoulder that was turned in the same setup as the OD so that they are concentric and perpendicular, which will provide the best balance, alignment, and strength. If you press it up to the cast ears, or just reference off of that narrow flange OD for alignment, there's no way to keep it square. Plus welding to the ears has a high likelihood of deformation if you actually put enough heat into it with a good weld. Everything they are saying is just the wrong way to do it. Probably squeaks by okay on a low speed offroad only rig, but that doesn't make it right. No way I would waste time doing it that way! (Unless it was the night before a ride, and it was the only option, then I would totally do it, BUT expect it to be out of balance and short lived)
"The 2.5" outside diameter tubing with a .250" wall thickness has the same 2" inside diameter as 2.0"x.120" wall thickness tubing."
Do they not understand how that math works? It should be 2" ID on the 2.5/.250 wall and 1.5"ID on the 2/.120 wall tubing, correct?
2" OD tubing has an ID of ~1.76, hence the yoke weld flange of 1.77' for an interference press fit.
This is not a backyard shop, it's a high end builder 🙄
The whole setup is just a half assed approach because someone was too lazy to research finding the correct alternative parts since the correct yoke is not available :dumbass:
I was going to comment on using a lathe ... then I saw the last pic. I have cut several driveshafts down and straightened them. Then had to grind off the balancing weight.
They balance them because mass produced d-shafts are crooked! I've seen them 1/4" +.
Once I get them around 3 thou I spin the lathe in high gear wide open ... smooth as silk.
With everything tacked up what's the best methodology for straightening? Weld it and use heat?
Before I tacked the yoke on and added the U-joint the runout was ~2.5 thou, the face of the adapter about 2, and about 1 thou along the entire length. I think the U-joint induced some error.
I don't know the answer, but I wouldn't use heat. Seems to me you could weaken it if you got it hot enough to move around.
Tap the u joint with a hammer until you get the answer you want :laughing:
Heat as in torch the tube in a spot and rapid cool it to induce shrinkage. This causes the tube to bend in the direction you want. Fairly common practice.
However after removing the live center/ arbor and yoke the runout is ~.003". Apparently I didn't make the arbor too close enough tolerances or the yoke is out of round.
Like I said I don't know exactly what I'm doing but I think it will be close enough for government work 😆
I watched a guy build mine once. He didn't balance, just used his lathe and got runout to around 0.001". He used a torch and soaking wet rag. Not exactly sure if applied on the high or low side though.
EDIT: You beat me to it.
Well hell, that makes sense. I would assume you wouldn't heat it to red. Do you?
Heat a spot on the low side cherry red and quench quickly. This shrinks it on the heated side.
Always had wanted a welding positioner but never justified one. Bit the bullet and bought a "cheaper" one from Vevor. Nothing too fancy but man did it make welding tube easy. Setup a piece of scrap and spent about an hour dialing in the speed and welder before welding up the DS. Makes a backyard hack looks like he knows what he's doing 😂
Once it cools it's back to the lathe for straightening 👍
View attachment 461666View attachment 461667View attachment 461668View attachment 461669
That's pretty sexy. And your ground is genius, like Wile E. Coyote super genius level. Filing that in the memory bank.
The splines being coated the DS had no ground though the positioner. After staring it for a few minutes trying to figure a solution, I remembered I had an engine ground strap I never used. "Hmmm......" It worked well, redneck engineering at it's finest 😁
After a bit of trial and error finally got it within 0.001" runout. I'm extremely satisfied with it considering I've never made a driveshaft from scratch. Some mistakes were made and lessons learned. After welding the runout was about 0.015", not terrible. Heated it on the high side (against what I thought)after watching some YouTube videos. Runout jumped to 0.035" WTF. Hmmm... holding it only on one side and not with u-joints (as true DS do) was the problem. Heated on the low side a few times and brought it right were it needed to be :dumbass:
I could have just ordered one but I always try to learn something and try new things. Definitely feel confident making the carrier shaft and rear shaft now. Thanks all for the advice.
