Appalachian American
Active Member
- Aug 31, 2010
- Hendersonville, NC
my rear 60 I think is out of a early 80s W-300 dodge. will your kit work? Saving my lunch money till spring for a kit.
Hey, I have a 72 J4000 Jeep truck with power drums all around. I'm swapping in a D60 out of a J4800, same year. Do I need to change my master cylinder if I install your conversion kit? How well does the E-brake hold on the E-brake style calipers? I use the truck as a toe pig. Thanks
awesome deal...free bump for ya shawnclip goes on the pad that is up agains the piston.Can someone tell me how to put the pads in. The pads came with a clip and two pads. I see how they sit in the caliper but can't see how they clip in. Probably something stupid. All I need to do is attach the caliper and I'm done.
Any chance you got a d44 tj kit? I'm getting desperate and can't find a set from a zj to swap out. Thanks
GubNi,
i have a 1979 dodge van b300 with a pathfinder conversion. i am restoring it and am interested in converting the dana 60 to disc brake.
73-87 chevy single rear wheel full floater 14 bolt axle 10.5" ring gear
I think I am going to use my SRW hub, but good to know.I do have a bracket for C&C if you use the C&C hubs.
The bracket is the only diffrerence. I suspect SRW hubs on a C&C axle would be the same as a normal axle, although I haven't tested it.
Brakes arrived today, thanks!payment sent!
