Macdaddy4738
- Jun 1, 2005
Question is, what should I pick up? My Jeep is a 1998 TJ (2.4l) currently with a 2" BB, JKS Disco's and 32" tires.
Ive narrowed it down to a few choices.
Full Size spare. Will a 32" tire fit on the stock spare mounting system?
Warn Rockcrawler front bumper. Right now I have a single tow hook on the front end, and would love to have those 2 d rings, along with the better departure angles on the ends of the bumper, plus its something to install rather than a spare which takes minutes.
Skid plates - I have a new steering box to install, and was thinking I mine as well go ahead and install a skid plate for the box at the same time I install it. Id like to get the gas tank skid at some point, just not sure if its the most important skid plate to pick up. Perhaps some differential protection?
Beef up the axle's - not sure I really want to do this, as the 30/35 are fairly useless beyond a 33" tire. I know I want to go to 33's eventually, but not anytime soon, and I dont plan to go past 33's until it dies and I need to rebuild everything. I figured if I went past 33' in size, id just go ahead and do the axle swaps necessary to put bigger tires on. Should I add anything to the current axles or just keep them the way they are?
Rocker Protection - Im thinking this would be the most necessary thing right now, but I've yet to find a decent set of rocker guards. I want ones that will allow me to use a high lift jack on them if need be. Id also rather have a pair that bolts to the frame as well as the body.
So of all the above, what do you think the 250 would be better spent on, and if there are other choices you have in mind, don't hesitate to let me know.
Thanks!
Thanks!
