RatLabGuy
- May 18, 2005
- Churchville, MD
Got some things on the $30 Jeep that need to be addressed.
I had an XJ several years ago, but that was before I did my own work and it was so good to me I barely had to do anything to it. So I'm looking for some guidance here.
I figure the two things I need to have for the race is gas, and brakes.
First, brakes. If you pump the pedal, it will build pressure (kind of)... but then if it sits for a few seconds, it's gone again. it kind of comes and goes. No obvious leaks... but the driver's front caliper has a torn boot on the lower piston (can see it from brhind the wheel), and seems to stick/grab if I slam it.
Thoughts? The fuild in the reservior was practically black. This weekend I'll bleed all the lines. clearly been sitting awhile...
Second: gas. If you feather it, it will rev and pull fine. However, going right on it (WOT) stumbles, then it will catch and rev. If you flat out floor it, it almost even chokes and dies. In drive, it feels like I'm really pushing it to go.
After sitting > 5 minutes, it takes sveral cranks to start. Iddle seems to have a slight miss. These are minor, but i'm guessing probably symptoms of the same problem.
To me this seems like an air/fuel issue. I can hear teh fuel pump priming when I turn the key to ON, so at least that's good. I disconnected the airbox and covered the intake line w/ my hand, it completely died, so (to me) that means no major air leaks.
thoughts?
I know I could just run it like this, but lets face it, doin ga race and having to feather the gas to WOT would just suck.
thoughts?
