independent361
New Member
- Nov 19, 2007
- Greensboro, NC
Ok, today i noticed some type of squeak coming from the drive shaft, i think. I have a 1990 nissan pathfinder 4x4, and it occurs at low speeds but then goes away when i start moving faster. Its almost like, squeak, squeak squeak.. like its moving with the drive shaft.. any ideas? i heard of getting a grease gun and taking the drive shaft out and putting some grease into the splines of the shaft and the transfer case, will this work? i sprayed some wd-40 where the drive shaft connects to the t-case and it went away for a while so im thinking the grease will work...
what do you guys think??
Thanks.
Thanks.
