andrewlail76
- Jun 21, 2006
- Hickory, NC
OK...
I'm puzzled...why is the towing capacity on a 98 XJ 2000lbs???
I thought these things used to be rated to pull 5000lbs!!!
What gives...crappier parts? Thinner metal? Jeep trying to evade paying for repairs if you break it?
OK...Edmunds must be full of
If you go through the other model years, the spec are identical(ie the 1997 has all the same specs, but can tow 5000lbs)
Editors should be ashamed...or did Jeep do something to build quality in 98 that killed everything because 98 on up, the max tow capacity is 2000 lbs...
..... Personally I wouldn't put more than 2000 behind either. Maybe a little more on the ZJ, but certainly not 5000. hell the curb weight isn't but 5000.
