Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
Aight first off I think I had a rather "doh!" moment today, which sucks if my hunch is right because that means I get to remove my driveline again for the 6th time since the Uwharrie 4x4cross, and get to shell out even more dough that I don't have right now
. I have sucky offidle power/response in the Z71 Jeep and also when I put the thing under load (crawling or boggin in a mud pit) the tires just stop turning real easy and bog the engine out, even in low range. So I just had the thought "hey I have been running turbo 350 torque converters from behind 350 motors, wonder if the stall speed is off in comparison to what a big block torque converter would run . . . . . "
would that be causing my sucky off idleness and ease of bogging downness?
Aight second problem, dangit my dang Z71 Jeep still overheats, and if you've seen the size of my freakin aluminum radiator then you know that something must be wrong. I built a fan shroud, have an e-fan that I always leave on, have a new water pump and 180 thermostat, even just replaced my top end with rebuiltish heads (hot tanked, polished valves and seats, new stem seals) and new headgaskets and whatnot. I mean I have drastically reduced the quickness that it heats up at in comparison to where it was before with the old cracked heads that were pressurizing the coolant system. She stays cool enough to where I can drive around for a bit, do single mud run passes, or like if i tried to do a timed rockcourse. But if i try to trail ride its gonna overheat. I did a 4th of July parade and was basically idling the whole time and barely made it throu the parade, was sweating it at the end, literally she was gettin real close to 240, I can just imagine if I was on the trail in low gear trying to go over rocks how quick it would heat up. Any ideas? kinda stumped on this one . . . . . .
I am running a Holley truck avenger 770cfm, runs good, I recently turned the idle mixture screws out to 3 turns out on both sides (from a previous position of 1.5 turns out on each side) it helped with the overheating, i just don't know where to set them at, everyone just says listen to the motor and see where it runs best at . . . well i mean it runs fine no matter where I put the screws - should I try to turn them out even more to fatten the mixture up more?
. I have sucky offidle power/response in the Z71 Jeep and also when I put the thing under load (crawling or boggin in a mud pit) the tires just stop turning real easy and bog the engine out, even in low range. So I just had the thought "hey I have been running turbo 350 torque converters from behind 350 motors, wonder if the stall speed is off in comparison to what a big block torque converter would run . . . . . "would that be causing my sucky off idleness and ease of bogging downness?
, aight thanks man will do
