gsrsol84mm
- May 30, 2007
- Charlotte, NC
Is anyone running 42 irok's on Toyota mini-truck axles ? They are listed as 20 pounds heavier than the 39.5 Irok's. A whole lot beefier than the 39.5's
Interco sends the rest of the tread when you step up to a 42.Is anyone running 42 irok's on Toyota mini-truck axles ? They are listed as 20 pounds heavier than the 39.5 Irok's. A whole lot beefier than the 39.5's
Bud in Colorado (moved from NC in April) is running 42" TSL on Toys upgraded. I know he blew the fawk out of the rear but those axles have been pounded on and pounded on by the stock F motor. The rear popped after the 5.3 install and getting traction on the western terrain.
42 iroks on a 85 runner, chromy everything , flanges 1/4 wall DOM shafts, cyro'd ring/pinions, no problems with this setup. First time out broke a stock 5.29 r/p in the front and destroyed some 1/8 DOM shafts. Pushing it with a 22re with cam/header/cone filter/full exhaust. Got the axles under my sami buggy now and getting ready to put the motor trans and cases in the buggy. The runner wieghed 3600 lbs and the h1 wheel and 42 irok tipped in at 149 lbs each.
Dustin doesnt know what to do with himself now that he has more than 110hp, huh?
Thanks for the replies. Would it be worth stepping up to the 42 Irok's if you had the 39.5's ?? Have std 22re with dual cases, 5.29's and 4.7 in the rear case. Really slow and steady. Truck not a buggy with 63 chevy's and 4044's up front. Enough room for the 42's with a little tub work.
