JThomas
- Jun 22, 2006
- Summerfield
I have to run a pulley off the crank on the left side of the motor. For p/s pump. Do I need the junk inside that cover. I could make a flat cover with a hole for the crank to penetrate through, then bolt the pulley, fairly easily. I think this is the charging side, and that is all it does? I allready have to have a belt... Why not have an external alternator also?
Now, my real question is.. This magnetic drum rotor? and coiled wires only have 3 wires to the coils. Stater? Would the 3 wires be? 1power 2gnd 3activate? Do I need to wory about them, or wire a standerd alt and roll. Main question is will everything work properly with this gone.
It would be nice if someone had an 01 750 to unplug his and see if it keeps running, only not charging.
" at the end of his post... No worries.
