cheapcherokee89
Active Member
- Sep 9, 2006
- oxford
im looking into puttin hydro assist on my cherokee. the down fall is spending the $900 on the kit. whats the easiest way to do it yourself ? anyone?
with a good full tie in front bumper and a steering box brace/frame suport, i'd say its strong enough.Is the unibody solid enough for hydro?
no the unibody is not solid enough, west texas will send you a tappe dbox then give you a core charge for your box then just get a psc ram and get hoses from tractor supply, you might as well go ahead and put a cooler in your line fluid get to hot and leaks out the cap
The Redneck ram setup is nice but you can DIY for less than $150.00 ... I would also go 1.5" bore 8" stroke from surplus center like the NAXJA thread...Really now....The Redneck ram setup is nice but you can DIY for less than $100.00 ...
Seriously, I did this for less than $100 as per my post above.Fixed it for youSeriously, I did this for less than $100 as per my post above.
I'm about to do this as well. I got my ram and hoses at a good price from Trailgear. If anyone wants to do the work and post up a link or two to the process I'd appreciate it.![]()
Jeepinmatt and I are doing it tomorrow. The jeep is at Tims shop in Hickory gettin some love, why don't you go give them a handYou get that shit done yet? Or for that matter, get your heep back yet? If not, I've done two now. It sucks, but I'll bring the tools and drink the beer while you do the work.
Anybody know where I can order a rebuild kit for my box(part number would be awesome), and would a stock ZJ box be up to the challenge? I've got two spares, and could sacrifice one to try this out. My pump wasn't happy the last time I spent 8+ hrs on the trail. SOmething needs to improve, I run sythetic ATF instead of standard powersteering fluid, and a cooler install is already in the works.
