braxton357
Robot
- Apr 6, 2005
- Morganton
How much vertical separation is there at the frame mount of the rear links?
using the ballistic fab units, not real sureHow much vertical separation is there at the frame mount of the rear links?
yeah, what he saidProbably about 4"
Thanks, it will be there.Just now seen this thread Matthew. Hate I've been missing it. That thing looks awesome. Can't wait to see it at the Caravan.
I like the way it sits now do you plan to stay with 35"s or go any higher?
cool buildI was going down a hill slowly when the front shaft broke. My guess is that the shaft was 31 years old and probably had a stress fracture in it already. I'll stay with the 35s for quite a while since they are brand new, but I've got plenty of room to go bigger without lifting more.I have a set of matching waggy 44's to put under my TJ when time is right. I like your set up lightweight and simple. I know everyone seems to push toward 60's but 44's are more than fine if you can mind the skinny. Were you beatin on it when your front broke?I like the way it sits now do you plan to stay with 35"s or go any higher?
cool build
Rubicon Express 4.5" in the front, Rubicon Express 5.5" in the rear. Gas tank clearance is not an issue, we cycled the suspension multiple times before we made it permanent. The rear axle is not forward, just an optical illusion. Action shots attached.Age gets the best of everything huh. What size coils did you use? Got any more action shots? Looking at your avatar it looks like the rear axle is moved forward alot. Gas tank clearance?
Did not eliminate the C bushing, we cut the Ford radius arms and built supports on it and used a builder bushing. I snapped these pics for you. I'll see if we have any pics of it clean.Did you eliminated the C bushing? I'd like to see a few pictures on how you modified/fabricated the mount around that area.
Great looking Jeep!
I was at the Farm at Halloween.Looks sweet.You are clearing those 35's by a mile. Were you at the last farm event in it? That mud looks familiar.
With the rear 4 link do you miss the rear sway bar on the road? How hard was it to center the rear axle?
Enough 20 questions![]()
