Dana 70 HD Rear Steer build at ECGS
Metto
Cornelius, NC
Customer was having trouble with his 9" exploding and decided it was time to step up to the big league. axle is a Dana 70 HD out of a '70s ford ambulance. was 76" WMS, will be 69" WMS to match the Dana 60 front. Will be running Rockcrusher and Solid inner C's, knuckles, 3/4 ton caliper brackets and steering arms; ECGS 35 spl drive flanges, ECGS Excalibur 300M joints and Nitro 4340 shafts. Diff is centered, pinion angle at 10*, caster at 5*.
Rockcrusher inner C's machined out to 4" for the huge Dana 70 axle tubes
Inner C mockup, still need to trim the tubes down a little. measurement from the back of the inner C to the WMS is around 11.625" (SRW chevy hubs and knuckles)
machining a chunk of a Dana 60 axle tube to make a inner seal housing for the Dana 70. still need to turn down the OD a little. will be running 2 Dana 60 inner axle seals side by side for ultimate leak protection :lol:
This axle will be very close to $3500 but It already has 5.13's and a powerlok. For an extra $1500 you could get gears, bearings, ARB. Still a good bit under a complete solid assembly. http://www.solidaxle.com/productcart/pc/viewPrd.asp?idcategory=18&idproduct=79
This will be ready to install complete with slugs, cromo shafts, RC Spindles, hubs, knuckles, and inner C's. A complete HP 60 with all new componets including center section with ARB, 300 joints, basically bomb proof. would be in the $5400 range as using conventionsl 60 stuff does not require inner C machining and custom seals.
this is a great option for a steering 14 bolt as well, we could do a totally decked out 14 bolt for around $5400, I have some 14 bolts avaialble and will be advertsing those soon. If INDY WILL would sack up and bring me some Portal teK Super 14's we could make one Steer :flipoff2: ill even put seal-it's in it for you.
No competition.
We've teamed up.
"Blunt Trauma Racing" will take on 2010 King of the Hammers with force.
Sounds like a lil nerfin' payback to Campbell this year won't be a problem with you two in the rig. Sam should be ok though, there aren't any trees in the go-fast sections.
Yeh, that is top notch right there. What size tires is the owner running?
tell me this isn't greg's
I was wondering the same thing...
Despite my love/hate relationship with the rockwells, I don't know that I could be without rear steer again.
i think he is running 40s. its in a full bodied ZJ with a 4.0
had to machine the seal carriers more to fit in the D70 tubes, which were different side to side
before and after
finished
installed pre welding
welded in
more progress, Rockcrusher finally shipped some stuff. still waiting on steering arms, hubs and inners
the beef
little zerk protection for the lower bearing caps
