15" tires on 16" rim
herbnuts3
New Member
jacksonville
i have a 98 silverado Z71 w 16" rims. my current tire size is 265/75r/16. i found a nice set of tires that are 33/10.5/15. can i mount these or no?!?! thanx in advance.
15" tires won't work on 16"rims. You would have to get 15" rims
Where are these people coming from? :alien:
You will need to get and adaptor to put 15" tires on 16" rims. It makes the wheel smaller so they fit.
I think Dylan had a set for sale pretty cheap.
Yep. PM Dylan, he can help.
Hey didn't a guy have a tire strecther listed under the classified a while back do a search and find it. When you find it purchase it, becasue it will be great for you to accomplish the impossible!:gitrdun:
hAHAHAHAHAHHAHAHAHA
what a question.....I wish that would have been on pirate
if you get them on there, you aren't likely to break a bead off-road
There is no "If"!!!! It is not possible to mount a 15" tire on 16" wheel the bead is made with steel belting in side it so it won't stretch. Heck tires go on tight on the wheel they are designed for, I couldn't imagine even thinking about trying to fit them on a one inch larger wheel.
I have to agree with the Rockcruiser "where do these people come from" :alien:
Pfft, all you gotta do is cone the rim a little bit and it'll slide right on with some grease. You guys don't know :poop:!
In all seriousness OP, look for a set of 15" rims. You can come across them pretty cheap. However, the deal you're getting on the tires may no longer be a deal when you add the cost of new rims.
If you go with 15" rims you will run into a problem with them clearing the calipers. 15" rims would work on 88's,89's and some of the earlier 90's chevrolets. Just try a 15" rim first and check for clearance between the top of the caliper and the rim. You may have to stick with a 16" rim.
Someone in the Tires FS forum was selling conversion Chevy wagon wheels, they are 15.5" diameter, designed to work with 15 and 16" tires.
