North
New Member
- Aug 23, 2008
- Gold Hill,NC
The fan will not kick on at high temps. It will come on, like it should when the ac is on. Please help.
If your talking about the fan control relay it's also used to control the fan when the A/C kicks on. I think if it were bad it would not work when the A/C was turned on either.There's a relay on the passenger side fender that's going bad. It's labeled in the fuse box under the hood. Replace it and see if your problems go away.
That sounds great, now how do I do that. Is that something I just plug in, in place of the relay?
Which temp sender did you replace? That year has two. One for the guage on the dash and one for the pcm.![]()
Good point Ghost. IIRC the PCM sensor is on the T-stat housing.
Thank you foreman1063, I made a jumper. It works perfect. Thank you all for your input!!!
