smoking vacuum lines
GotWood
Sayer of Fact
Maiden, NC
I'm having problems with my wife's Intrepid:shaking: again, but at least this one doesn't seem to be too serious. I am throwing a 441 code. I have heard you can use a machine to pump smoke into the vac system to find leaks. Anyone here do this??
You can use Oxygen too....or either
I have used a hand held propane torch to find vacume leaks. Idle the engine & allow the gas from the torch to blow (slowly) around the vacume lines. When the engine idle goes up you have the area you leak is in.
I do the same thing but with starting fluid. Also cleans your engine off at the same time
This method works great. Just make sure the torch isn't lit. :rolleyes:
I've seen people burn wiring harnesses up using this method.
