tkob1060
Active Member
- Oct 9, 2009
- HIGH POINT,NC
Ok see if you guys have some ideas on what is causing my tcase to crack to pieces around the front output shaft and dump all tcase fluid. I have an 08 JK unlimited rubicon, running 5:13 gears, aftermarket front 1350 double cardan driveshaft which was replaced with brand new one after the last case blew up. The first time the case blew up the double cardan joint was busted and that was believed to be the main cause of the tcase cracking along with the transmission crossmember being bent from a couple rocks that got in the way.
I do have a steering wheel shimmy from 35-40 mph that I am sure is from my highly worn 75K mile KM2's and maybe toe being off slightly. I was planning on replacing the tierod and adjusting the toe this weekend. I was also going to order tires this week now thats on hold till I find out if dealer will warranty the tcase again and figure out whats causing the trouble for sure.
I believe it has to do with the steering shimmy this time but they insist that wouldnt do it, which makes sense because I read of plenty of people with the shimmy and no exploding tcases. The driveshaft is not broken this time.
Here is the REALLY crazy part, it blew up less then 1.5 miles from where it happened back in May on I95 in SC south instead of north this time.
Same tow truck towed me to dealer.
