mbalbritton
- Mar 22, 2005
- Orlando, FL
How do you determine the best timing for your engine? How do you know if 5 BTDC is better than 10, or whatever?
Why not set it to the factory spec?![]()
On older carbed engines you can set it to factory specs if timing gears/ chain are relatively new. On an engine pushing 100k the chain will more than likely have some play.
If it starts fine and seems to run good except for running rich, I'd leave the timing alone.
1. don't know what factory spec. is on it.
2. ain't nuthin' factory about this truck, certainly not the engine.
3. If factory spec is good enough, why are they adjustable at all.
quit being a smart ass Caver!
Was gonna suggest you stop by when you come to W-S and we'd throw the timing light on it, but you obviously have a "better" plan...rejetting was a thought too, but it's a stinkin' 2brrl Carter (I think) on it.
Before electronic ignition controls timing could be adjusted by advancing till pre ignition or pinging occurred and then retarding a degree or two. The pinging would occur on acceleration so a test drive was required. This method would take in consideration octane of fuel, carbon deposits in combustion chambers and other factors. I had a 67 Ford van that owner's manual specified this method.
