NOT even remotely applicable to the OP's request regarding a NT D30 in a
CJ
are there any special tools needed to pull the hub and knuckle? im a deisil mechanic so i can do the work, just some of the 4wd stuff is new to me
Depending on whether you have lockouts or Q-trac "drive slugs", you need to remove them. Most lockouts use Allen head bolts to attach to the hubs. Once the outer lockout is removed (depending on whether anyone's been into them prior), you'll need a set of EXTERNAL snap-ring pliers to pull the snap-rings off the end of the outer stub (axle) shaft to pull the inner "spacer" portion of the lockout off.
From there, you'll need a punch/prybar to bend the tabs up on the lockrings for the spindle nuts.
** If you have the old Warn "Lock-O-Matics", they used a round outer spindle nut held in place with setscrews ** . Assuming you have a late model with discs, remove the caliper lock bolt & key (with a punch) and bungee the caliper out of the way. Then remove the spindle nuts, inner/lockring/outer (I've always used a chisel to get them started) and pull the hub/rotor off.
Once down to the bare spindle, remove the nuts that hold the spindle to the knuckle, and using a WOOD block to protect the spindle, BFH the spindle side/side-up/down until you can work a prybar between the spindle & knuckle. Be careful nut to booger up the surfaces or warp the spindle flange prying though. (After this exercise, You'll see where to apply the anti-seize when it time to re-assemble
). Slide the spindle off the studs...
Then just grab the outer stub and pull it out.
15-20 minutes to remove each side working at a relaxed pace and not running into anything like seized/broken/rounded nuts & bolts... allowing time for an occasional sip of adult beverage
I'd also recommend checking the spindle seals/needle bearings and hub bearings for any wear/roughness... since you have them out on the bench, it's the best time to replace them if needed. Clean & repack the hub bearings & clean the rotor/pads before assembly.
