Bildo
- Sep 17, 2006
- Charlotte, NC
Where did you buy all of that from? I did 40' of 8-3 stranded wire like yours with the respective 220 ends for a while back for <$70 at lowes. Hobart actually says that you *can* use up to 67ft of min 14ga...so.
If you're using a buzzbox though, that's more than twice the input amperage--migs at <20 and a 225 stick at 50A--in which case 6/3 is pretty well suited.
Agreed that the RW is a good idea, though in the two years I've had one I've never used it connected to a mig or stick welder so I can't comment there...
Or you could just tow the rig to someones shop that will help you out.![]()
I draw 50A. About $35 for the Forney ends at Ace and $110 for the 30ft SO cable at County Electric near Home Depot in the University area in Charlotte.
6ga is what is recommended for 50A but you can get away with 8 if you are running a short distance. This SO cable is flexible and will last a good long time.
