mw312003
Member
- Jan 1, 2011
- taylorsville
Anymore heard of this or tried this I would like some input if anyone has tried this before. Thanks
go for it the wastegate is not real critical on a diesel been running mine blocked off for about 8 years
Your joking right?
...and stock powerstroke vans are not running a 24V cummins either... it's all about the setup
you can plug/turn up the boost all you want, however there is a limit to the benefits of a stock, street driven truck that you will encounter... it's all dependent on your entire setup - fueling/wastegate/exhaust/intake/tuner
but if you must, set it to 35psi, get a boost fooler & tuner, downpipe and intake and call it a day
No I'm not joking what burns up turbos or pistons? Egt. Boost is boost every pound of boost is 14* of temp that's why you run intercooler or nos if you not making anymore power you might look at that you block off the wastegate the turbo is going to make what its going to make now defueling ,head gaskets or any of that I don't know stock power stroke van turbos don't come with wategates at all
It is nice to know that at least one person on this thread isnt a dumb ass when it comes to understanding this process. The rest of you need to go sit down and listen to the teacher.Additional fuel makes additional power, additional fuel requires additional air to burn , additional air results in additional exhaust gases, additional exhaust gas results in higher drive pressures. Which equates to higher boost.
The turbo is designed to "move" said volume of air at any given speed, boost or drive level.
Once the ratio is exceeded , let's say we exceed the map by 5 lbs drive pressures will show this and the drive pressure boost ratio will begin to "flip". Take it to far and your lucky if the charger goes before the headgasket.
You will never over spool a non gated charger without additional fuel. Because the initial design never intended to move as much air as the turbo was mapped for.
24v trucks use the wastegate often and in factory state a little early. It's ok it increase a touch we are not talking controlled increases, we are talking blocked off.
Just get an adjustable orfice or fixed orfice elbow that slows the flow to the actuator. Regardless it will still open the gate fully at the same pressure, it will just take longer.
You are trying to out smart a room full of well paid engineers and simple physics. You are not winning.It is nice to know that at least one person on this thread isnt a dumb ass when it comes to understanding this process. The rest of you need to go sit down and listen to the teacher.You are trying to out smart a room full of well paid engineers and simple physics. You are not winning.
My current 24v has no waste gate and has not had one for years now. I built a twin turbo setup for a cummins 4 years a go with out a waste gate and it's still running fine that's all I have to say on this subject.
Nope, your response was not retarded.I hope your not talking about me
