- Mar 20, 2005
- Morganton NC
Kewl Thanks Kenneth. Are the ones at Taget undercounter/cabnet? Trying to save much needed counter space
I've got a stick vaccumie thing I'll give you. Stop by one day and pick it up. it's something kinda like this but not exactly.
Here ya go!My hometown of Rocky Mount...you probably found the only thing worth buying thereWould love to see interior pics!
Lowes has the undercounter coffee maker, I beleive it is a Black an Decker. We use a Coleman percolator that sits on the burner and takes up very little space. $10.00
they make the best coffee because there both coffee addictsAnd they make the best coffee too
Dang Leslie you can't be to picky IT'S FREE.A powered, bagless, stick vacuum?
Buy a cheap 8 dollar toaster at target. Something you can stow easily. Toaster ovens take up alot of space.I'll have to take some pics to 'splain it better, but...
The major issue with the kitchen is that there is basically no counter space to sit things. There is a small area behind the sink that we put the coffee maker, but, it is in the way when cooking. So instead of moving replacing and so on back and forth, we want a space saver type coffee maker. It will attach under one of the top cabinets or shelf. out of the way and using only air space and not the counter. I have even thought about getting a toaster oven that also fits under the cabinet as well. While the gas oven works well, you can't toast like you do at home. You have to flip the toast once the butter is absorbed because it will toast on the bottom. Not much room under the actual heating element(flame)
But it does have a micro wave convection that is great. Makes the best cobbler that you can imagine!
