maddog411
- Mar 22, 2005
- Harrisburg, NC
Here's my truck, I'm sure some of you have seen it. It's a '96 Chevy K1500 with 350 vortec, 4l60e, and np241c transfer case. I have spent roughly the last year working on it on and off and it currently has:
Front:
ORU Solid Axle Swap brackets (adds 3" lift)
12" superlift front springs.
ORD Zero rates in front set 1.5" forward
Rebuilt HP Dana 60 w/5.38 gears and stock shafts
New front driveshaft with longer slip and 1310 cv on the transfer case end.
Rear:
6" Rear BDS Springs w/add-a-leaf
ORD Shackle Flip
ORD Zero Rates set in center.
3" block
rebuilt 14 bolt with 5.38 gears, detroit, disk brake conversion, 1350 yoke
1310 CV on driveshaft
3" body lift for 18-19" total lift.
I originally put 49" Iroks on it but found problems so I traded for 44" boggers. Despite the high arched springs they are not unflexable, in fact here's how bad the 49's fit on the trail.
Hacking wouldn't help that much because they also hit the outward bend in the frame right behind the front wheelwell.
So here's the dilema: I'm obcessed with getting bigger tires to work, and inspired by the toyota on 52's
. I'd still like to be able to use the thing as more than a mud bogger, though. I'd like to put rockwells and the new 54" boggers on it. I would need to work on getting the front axle even farther forward and maybe need a little more lift. I know COG is a problem but hopefully rockies with the hubs out will help that alot. So I am asking for ya'll's input into this. I fully expect that I will get bashed as well.
Front:
Rear:
ORD Shackle Flip
3" block
daayum... thas a HUGE bi***
