Zachs
Active Member
- Mar 24, 2008
- Kinston, NC
back story:
Alright so after showing off at URE in late 2010 the Jeep became a lifeless pig. What happened was at the top of daniel I started crawling over all the rocks people show off on and found a rock that cut my rear yoke enough that is caused the driveshaft to fall out (only thought the strap to the ujoint broke).
Replaced Ujoint and strap and left the outpost and thats when I found out what really happened. DS came loose and I immediately stopped and remove it which is when I realized the yoke was broken as well.
Got home, replaced yoke, replaced ujoint. Also noticed one of the TRE was bent to shit so I replaced both just recently as well as the unit bearings.
0-20 no issues at all, any faster under acceleration and I've got vertical vibrations bad enough to shake the stereo loose. as soon as you get off the gas and just roll (no matter how fast) there or no vibrations at all. Touch gas and vibes are back.
Not Deathwobble
Not Deathwobble
but of course the vibes continued...thats when I took off the DS and checked the yoke movement.
