C.Berry
Bad News
- Aug 10, 2008
- Blacksburg, Va
Ok situation is now...
took off valve covers to adj valves and found a rocker unseated from spring and push rod bent... took rocker off pulled rod looked at rocker stud and it had been almost cut in half from the rocker sooooo i try pullin the stud out it broke go damn figure, well i have engine broke down head off and was wondering if any of you fella ever had to deal with this? about a 1/8 in of the stud is still visible so need to figure out how to get it out so i can tap for screw in studs b/c the engine has aftermarket cam and i blame it and PO for this happening and myself for not lookin before now!!!
Any suggestion would help trying not to damage the head cause they are in really good shape from what i see so far thanks in advance. All of yall have helped with alot of my Q's so i came here first lol
Works good on welch plugs in a engine block too.
