paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
That helps alot. I was reading through that thread on pirate, but it was 218 pages yesterday.
Sounds like I need to buy the DANA builder inner C's mentioned earlier and use 3.5in DOM pressed into my dually 14 bolt.
Only other option I can think of is to remove the tubes from my 60 and machine out my 14 bolt housing for the 3.75 tubes.
Will need to take measurements of 60 so I can use stock length shafts in my 14 front.
Check the ovality of your 14b tubes/housing. I cannot recall what versions, but I have read folks talking about 14b tubes and housings have oval tubes vs round.
Here it is: Most desirable 14 bolt center for front build
patoyee said:It's been a long time since I did my research on this so please don't consider this bible truth. But I think the ribbed housings are thicker where the tube enters the housing. And I think it's the SRW ribbed housings that are thicker there still. Also the ribbed housings use actual DOM axle tubes whereas the older non-ribbed housings use that weird oblong stuff that isn't even close to round when you really look at its cross section. At some point they increased the size of the pinion nose bearing as well. I don't know when.
14-bolt thick casting?
There is other good info in that thread. Could copy it here, if preferred.
Also, found these 2 threads with some 14b builder info:
The right foot worthy 14 bolt
https://www.hardlinecrawlers.com/threads/best-way-to-remove-14-bolt-tubes.58926/
