holdmypocket
Member
- Sep 18, 2025
- Charlotte
I documented the start of this build on Irate but since I moved to NC December 2024 I thought I'd continue it here as well so I'll be light on the details up to the present (unless anyone wants to see something specific).
This is something I've wanted to build some version of since I was in high school in the late 90's reading 4 Wheel Offroad and Fourwheeler. My favorite issues were the ones covering the Ultimate Adventure and Top Truck Challenge. Instead of an F-series though my first vehicle was a 1974 Bronco. I learned how to wrench and fabricate on that and made some great friends in the Early Bronco Community in San Diego, CA.
After several Broncos, life, etc.. I found myself in Norfolk, VA in 2017 in need of a cheap daily driver I could maintain. I found this 1978 F150 that was stock on 31's (351m, C6, NP205, Dana 44, Ford 9). Had some rust but I could weld and had seen worse. The plan was get it safe, reliable, comfortable, and on 33's, then upgrade the shafts, minimal lift, and put it on 35's with ARB lockers. I picked it up in Charlottesville, VA and drove it 3+ hours to Norfolk. Did all of the above upgrades up to just before 35's and lockers. It was a reliable daily driver that I did a few road trips in, was very happy with it.
Then I found myself moving back to Southern California (Orange County) in 2019. Blew the engine (oil pump shaft broke in half). Installed a remanufactured 400 with an rv cam and then I had to get it to pass smog in CA. Took a year but managed to do it buying parts on eBay, learning how to read the vacuum diagrams and test everything myself. Had the C6 rebuild and then I enjoyed it as my daily driver for a few years, installed Vintage Air AC, and started collecting 1-ton parts.
Eventually I was able to afford a car for daily-driver-duties, which is when the fun began. It went together pretty smoothly because I had a lot of time to learn/research/etc. It took me less than a year to get it on the road working on it after my day-job. It drives great/straight down the road and does 70-75 mph on the freeway (the 400 is torquey but lacks horsepower).
The details:
- 2006 Dana 60 4.88's Eaton E-locker
- 2014 Sterling 10.5 4.88's factory E-locker
- 40x13.50x17 ProComp Xtreme MTR tires
- 17x9 ProComp Wheels
- WFO Radius arms with Metal Cloak rear joints (set caster to 5.5 degrees)
- WFO's Super Duty drag-link, uses rod end on the frame and stock tie-rod end at the knuckle
- DOM and Rod ends for the trackbar
- Barnes trackbar mount on the axle
- Custom trackbar mount on the frame out-boarded 8"
- Battle Born Brakes Coil bucket on the frame (bolts up and uses the stock Dana 60 spring and coil cup on the axle)
- 1-2" leveling coil (forget the brand)
- Deaver 10-pack springs in the rear with a BroncoAir.com adjustable-shackle-flip
- Bilstein 5100's
- 2019 Honda Accord electric iBooster with stock master cylinder (needed to efficiently move the big Super Duty calipers)
- Saginaw Steering pump
- Lincoln MKVII fan with PWM control from autocoolguy.com
- Exhaust manifolds to a single Magnaflow knock-off muffler out behind the axle on the passenger side with a turn down
Then we decided to move to Charlotte. This brings us to today where I'm currently working on correcting/redoing my hack wiring and installing a Dakota Digital gauge cluster. I haven't even had a chance to do a real shakedown run yet but I daily drove it around town from December to April. Then I got myself a 2018 Super duty to DD and eventually use as a tow rig.
Here are some pictures:
The details:
- Bilstein 5100's
