- Apr 16, 2005
- Sharon, SC
what kind of meter do you have?
Greenlee DM20what kind of meter do you have?
Fuel pressure key on engine off is 60 then drops to 55
At idle it's 49 psi
While driving it sits at 42 psi and highest it goes is 55 uphill wot
fuel filter is good also
We’ll ordering delco pump tomorrow! I’m sick of this sluggish burb engine has 189k and seems to Be awesome shape trans seals and in pan was surprisingly perfect filter wasn’t even that bad! Pump it is again lol luckily I can do pump in like 30mins with section cut out in back now! I’ll def post up resultsJust coming on the last page of this, but I had a 98 5.7. After, a fuel pump change, It Stumped great mechanics, Scanners, & a Dealership! I kept getting emission codes. Everything related was changed out, & even a smoke test run. On a Trail ride, Jason Lackey heard me talking about it. I had bought & installed an Autozone fuel pump. Nothing wrong with the Pump, B U T, the dang tank pressure switch, was Not compatible with the GM computer. GM/Chevy, had a Bulletin on this, but I guess the Dealership Didn't read it. ONLY the AC/Delco sensor, can be used. That Fixed the problem, that had everyone Stumped. Sounds like you got another "Stumper"! Good Luck!
