91samurai
- Apr 20, 2016
- Midland, Nc
I was driving the k-truck the other day. And it hit me, how am I gunna strap my tool cart in the back to take it to the dealership? I had to figure something out that could withstand some force and I've always thought stake pockets are good but often not well thought out. Often you cant hook just the top or pass the hook of a strap through the slot.
After cutting the hole the stock sheet metal wasn't going to cut it, so I cut some plates out of 1/8 in flat bar. Hole-sawed, then plasma cut, then ground out to be an oval with a carbide burr.
I marked then cut the bed with a holesaw and an airsaw. Next I tacked the plate to the bed. (excuse the porosity there was a gust of wind right when I pulled the trigger)
Ground the bed to the same size as the 1/8 plate with the carbide burr. I fought the wind the entire time I was welding this side.
I spread some rtv around the inside of the slot, to stop moisture getting in-between the bedside and the plate.
Out with the broken slider and in with the solid back window. Saturday night I cleaned up the flange and painted the rusty spots. I had every intention of installing the back window on Sunday, but I had some serious allergy issues. No photos but my Dad and brother installed the back window for me. (thanks guys
On Thursday night I bypassed the switching valve and took it down the road, No dice. It still fell on it's face in 3rd gear. I've got two new sending units and gas tanks on order. I believe that the pickup in the driver side tank is clogged up. I currently only have one tank installed, the driver side tank with the passenger side sending unit in it.
. I removed them immediately and bought a used set of stock lights. Until now i've been just driving around with the holes in the fenders, you can see the marks from mud coming out of the hole.
